I replaced the entire assembly. If you your odometer worked immediately I am going to guess that I might have some sort of other problem, probably a wheel sensor or something like you mentioned. The Traction control is not functioning either. I will start checking the wheel sensors and their wiring here in the near future.
The good news is that even without the scanner bleeding of the ABS unit the car still appears to stop like it did before the swap. The standard brake bleed brought it back to "normal" but I am going to drive it to a buddy to have him bleed the ABS unit too, then I will try to figure out what the real problem is.
