I've been messing around with the system to see if I can pinpoint the issue better. If I let the car warm up to the normal operating temp, needle in the middle of the temp gauge, and then turn on the system the air works great. It seems as though there is nothing wrong with the system. If I start the car with the system on or turn on the air, the fuse blows right away. I unplugged the aux pump to see if that may be the cause of the short but the fuse still blew.
I think I can rule out a leak, compressor, clutch coil as the problem since the system runs fine once warmed up.
Am I looking at a defective DCCV that I installed, or could something else be causing the short to blow the fuse?
