chris2523
93 Mark VIII
you can also use a chip to turn off the egr. that will also turn off the light and tune to run without it.
The thing about removing CEL bulb is you would never know if real CEL is sent.
any c.e.l that is going to be sent on his 95 obd1 that he would not be able to tell he had a problem by drive ability issues or misfires is irrelevant, your engine could be catastrophically wounded, leaking oil, blown head all that b.s. and your c.e.l could still not turn on if your not misfiring. all your c.e.l does is tell you when your vehicles EMISSIONS are failing LMAO its a juke, its a light that bring you to the STEALERSHIP so they can A$$ rape the life out of you for a o2, or a evap purge, or a evmp "egr position sensor" so on and so forth. so rip the light out and unless you get a misfire, "will make the car shake" or your average mileage drops more than about 3 or 4 points between tanks than just drive her.
Update:
We did remove all 3 cats, and mounted some nice Raptors mufflers, great sound and hopefully better fuel eco and perhaps a few hp? We put the O2 sensors back in the same place as before, just now on new pipe, no cats.
When driving from the garage everything was just fine, BUT after few miles, the "Check Engine" light came on
The engine is fine.
After 1 hour at home I did start the engine again, and no "Check Engine" light. I went for a short drive and after 3 minutes drive it came on again... I stopped the engine for few sec and started again, no light, then after 2-3 min drive it came again, etc...
- I have not yet found a error code for this, but will write it here when I have, but again it could be difficult to do as the error only occurs after driving for 3 min...
- Anyone here have an idea what this could be?
I did the same thing on my Audi TT few years ago, I remember we did move the O2 sensors few mm from the pipe until it "fooled" the computer. Can we do the same here, will it work?
Will this error message have any affect on the fuel consumption? I presume the engine will be fine even this light is on?
Was it hard to remove the driver side cat? Can you please tell us your procedure.
