Did I break it or is this a timing chain issue?
gtate
Jacksonville
Yesterday I replaced the water pump and thermostat. I filled everything up with coolant and started the car to begin the cooling system bleeding procedure. Initially (for the first 30 seconds) everything went as expected. Then I heard a really loud ticking from the front of the passenger side of the car. I cut the car off to see if I had dropped any tools on that side that I had missed that were being hit by a pulley or something. Nothing seen so I started the car again. I listened for a bit and localized to the front of the PS of the engine. The car was running fine and so I increased the RPMs a bit to see the effect on the sound. It smoothed out and got intermittent for a few seconds.... and then all hell broke loose. It sounded like a thousand ball bearings hitting the inside of the motor at 100 miles an hour... or maybe like a nut dropped into the intake that made it's way into the cylinder.
Now if I start it at all it still runs like it's on all 8 cylinders but it also sounds like something is trying to escape from inside. My first paranoid thought was that I actually did somehow drip a nut or screw into the throttle body but I really don't see how I could have done that. All screws were accounted for when I was done.
Do the timing chains make this type of a noise when something breaks? Maybe a tensioner?
You have something else going on. Some thoughts (not a complete list at all)...
Bad idler.
Bad Cat.
Loose exhaust manifold.
Those all are external. This sounds like it's internal to the engine. Could be wrong though.
If you're sure it's internal, then pull the valve cover off and see what is going on. If you don't see anything else, check and see if the cams are moving (other than rotating).
Well, I am officially an idiot. I did pull the PS VC and replace my coil packs since I was in there. Also noticed the VC gasket was leaking oil into the rearmost plug recess.
I couldn't see anything wrong so I put it all back together and cranked it up again. Now the racket was coming from all sides of the front of the engine. Close attention this time allowed me to see that a piece of the serpentine belt was stripping away banging on pretty much everything in the front of the engine. Just goes to show that paranoia, dehydration and the very hot Florida sun don't go together.
I'm ABSOLUTE SURE you're the ONLY one to have had something like this happen!!! NOT!!! I spent an hour or so trying to remove the A/C compressor being absolutely positive I disconnected the plug. After taking a break I went back to work and noticed the attached plug..... DOH!!!! :slam:slam
