Hi, I have a 94 Mark (Canadian), and I just got my mechanic to install an HID set-up from a 96 LSC (USA). It works great, except for one worry, the daytime running lights are still in operation, and it's the HID's that are being powered up by the DRL's.
I used the search function, but can't find a definitive answer as to how to disable the DRL's. I'd like to accomplish this as simply as possible. By unplugging the DRL module, will this do the job, without disrupting anything else? If so, where is the DRL module located? Are there some wires I can snip that would do the job? If so, which ones? If those two options won't work, is it possible to have the DRL's power up the high beams instead of the HID's? If so, how would I accomplish this?
If there's anyone that could provide me with some technical guidance, it would be much appreciated.
Thanks,
Bryan
Thanks,
Bryan
