dnsherrill
not that it matters, since the engine is gone, but wasn't '94 the year that there were alot of problems with the valves or something?
thx for the input
I wonder how much the tranny with 120k on it is worth...I may just try and get the grill, lights, brow, and tranny....mine has a front seal leak and 173.5k on it, but is shifting fine, for now
this is not a C/L listing...but I met a guy at the local AZ with a wrecked 94 Mark...T-boned at driver door, rear 1/4.....120k miles; clean interior and ext where it's not hit; the engine is gone;
tranny is in the trunk and apparently in good shape, possibly rebuilt if he has documentation
....front clip is clean, rear lights are good; interior is tan, and clean...coils have been removed; a hub swap was done-5x4.5'' with stock brakes and bored rotors
....for $650 he'll drop it in my driveway.....hmmm
should I do it?
How difficult is the seat removal...Just wondering because there is or was a black on black 94 that i pulled parts off of at the Charlotte pull-a-part. Thanks, Scott
Oh, you shouldn't have said that. I'm headed to Charlotte pull-a-part right now for those seats!jk
Seriously, it's not that bad. Like Markviiiedrea said, it's easy if the car has power, but I know from my experiences at pull-a-part, I've never seen a car with a battery in it. When I got my seats (got them from a guy in Huntersville, actually, just north of Charlotte), when I showed up to pick them up, they were still in the car, and the seller and I pulled all the seats out in about 10 minutes without a problem. You might want to read up on here how to pull the seats, so you know what you're doing in advance (I think someone on here was recently asking about how to pull the back seat, so there's a recent good post on that I know). Good luck! I hope the seats are still in it. I know every time I've made the trip to Charlotte to get parts, it's been a bust because everything I was looking for was either damaged or already taken, but, then again, I've only been there a couple times.
They are a little bit of a PITA because of the bolts underneath the seat rail. If the rear ones are covered you can be there quite some time.
gonna meet him tomorrow, he pulled the grill, headlights and corner lights, chrome brow....will take $100 for all that; now to scavenge what's left...this is not a C/L listing...but I met a guy at the local AZ with a wrecked 94 Mark...T-boned at driver door, rear 1/4.....120k miles; clean interior and ext where it's not hit; the engine is gone;
suggestions?
VRCM?EATC?bezzle? rotary headlight switch? what else?
I'll offer $100 for the tranny, maybe I can use it as credit if/when mine needs rebuilding...I'm going today.....hope to get the wiper motor and EATC assuming they are compatible with my 96 (parts car is a 94)
I've not pulled the wiper motor before...any tips? arms, cowl, motor assembly out?
No I believe that was only in some 95s which had bad valve springs..they had a tendency to break..not sure what the difference was between those and the rest though.
I started out just wanting that grill, (mine has been missing a tooth for about 3 years) which is in VERY GOOD condition....the other stuff is gravy...best part is the kid's dad, who builds cars there, pulled everything but the VRCM...apparently all of the front suspension (ball joints etc) was replaced about 20k ago...the kid has but doen't need the IMRC's which hold VACDnsherril, sounds like you didn't do too bad. The transmission alone should be worth $300 if it works. If it's rebuilt like he says it is, even better!![]()
