turn_on68
When you are replacing the tranny in a Mark VIII do the new transmission lines need to be flushed?
Mainly the cooler, but yes, the lines should be flushed, especially if it is being replaced due to a catastrophic failure. I am not sure if there is a section of rubber hose in the cooler line, but those in line filters with magnet (magnafine?) that you just leave there and it bypasses when clogged should be included too.
Why wouldn't the tranny filter catch that?I guess it all depends on what you find suspended in the fluid, and at the bottom of the pan. If it is a problem with worn or smoked frictions, or something is metal to metal and wearing, then it can be in the lines and cooler.
A number of companies have cans with solvent, compressed, with adapters to fit the lines at the transmission. You remove both lines at the transmission, plug in the can to one, the other into a container, and flush it.
Sounds like you are in need of a trans rebuild/replacement. If you or any one else is going to do this be sure that the lines are flushed, and you get a new torque convertor as well. When the clutches wear the particle size is so small that they often are not totally filtered out, and if a trans has been neglected and abused then you can count on this contamination being everywhere. This is one of the reasons they recommend filter changes. All of this contamination also finds itself in the TC, which serves as a very efficient centrifuge and debris catcher. This is why you need to install a new one. They aren't that expensive(stock). Based on where you live I'd also get a plate type transmission cooler installed, as well as getting a drain plug installed in the oil pan. Make sure that you use Mercon V fluid also. Get a couple extra quarts, and while you are under the car flush out and replace the power steering fluid with the new Mercon V.
Thanks. Are you saying use Merton 5 transmission fluid in the power steering and not power steering fluid?
