Double din radio installed today (pics)
The episode will air on 9/20 there are four different HHR's being build on the same episode so I dont know how much I'll be in it. That means about 5 minutes spent on each car.
hey how much can u get the that unit for. And maybe you can put a price and making the stereo adapter, that is if somone were to use the same system and send you the stock set up to make the kit. Right now just a few questions, really like your work.
The Heckler said:
I made the dash kit out of the face of the stock stereo. What do you think? By the way, Does anybody have the stock metal radio brackets laying around? I need some extra's.
Where did you mount the gps receiver? I mounted mine on the dash, but it doesn't get great signal. How much would you charge to make one of those trims for me? Thanks
I put my gps ant. on the dash and works very good. I've never seen it drop under the 4 satelite signals unless i am going into a matal shop or something like that. It works in the garage parked. i will admit i hate the way it looks just sitting on the dash anyclever ideas where i could mount would be nice..lol..
if you can get under the dash..you can mount it there...the GPS antenna CAN see thru plastic as long as there is no metal blocking its view to the satallite.Try that.
I would probably charge $200 to Do this install. The trim piece does not take as long as getting everything to mount in the car, and lined up perfectly. As for the gps antenna I put it on the dash trim close to the window, but I put the grounding plate right under the plastic panel.
How much would you sell the trim for? I would like to buy one if the price is reasonable.
The trim is my old stereo routered out. It takes a lot of work to get it right. Expect to pay some $ if you want it done.
"THE HECKLER" how much for an install like that? did u have to fabricate anything?
