LINKAGE03LS
I noticed a little hole in the hose and it was spraying into the throttle body so I cut it back put it back on cleaned it the best I can. What I'm getting now is intimate fail safe rough running when I said it back with my code it runs good for 10 miles give or take and then goes into fail safe with check brake again. I also noticed a little dribble of coolant coming out of the bottom of the throttle body doesn't seem to be by the pipe on the passenger side. I was wondering if I clamp down the feed which I believe comes off of the thermostat housing if that would remedy the problem till I can order the parts. Thanks always in advance your input fellas please. Let me know if anybody's been successful and had this problem before.
