You're more than welcomed for whatever help..
"...If all wires from the individual components in the system run directly back to the controller..."
According to the wiring diagrams, that O/R wire does make a straight run to the trunk connector (with one big intermediate suspension-wire connector somewhere.. maybe on the firewall or in the dash.. somewhere at least partially accessible.
(I could search it out in the vacuum line/electrical connection manual.)
At the controller in the trunk the O/R wire is conveniently at the top outside corner of that large connector, so snipping it would be easy once it's exposed. Look and you'll see what I mean.
If you want to try that, cut it at the wheel and the connector in the trunk and lay about 10 or 12 feet of wire across the roof of the car.
Leave a few inches of slack at both ends to splice in the new wire.
Instead of twisting copper strands, they also make these clips you squeeze with a pliers. They puncture the existing insulation and you can add a wire along side existing (Home Depot or maybe Radioshack)
But you still do want to cut the O/R at both ends to get it's length out of the circuit.
Replace the questionable solenoid..
Then just see if the system acts like it's supposed to.. or run the diagnostic tests.
..can't really drive around like that.. but it may prove the O/R was the problem.
There's a chance the O/R is mistakenly touching something like a clock wire.. an alarm system wire.. or some circuit that is always alive when the battery is connected.
If so, a voltmeter across the solenoid connector may read 12V with the battery connected because the
O/R is then grounded, and yet it's not grounded without the battery.
"...Yeah, I mean NO reading. No reaction by the meter whatsoever, so infinity I believe...."
Sounds like a problem with the meter, like it's not stable for some reason. An infinite reading often defaults to something like 3.000M ohms..
No reading in the screen makes me think batteries are low or there's some voltage running in the wire, there's a fried internal fuse, or similar..
