Just swap the ecu and take it to the dealer. This is not a reflash. They need to go deeper. Here is the procedure FROM THE SERVICE MANUAL
Disconnect the battery ground cable. For additional information, refer to Section 414-00 .
Remove the cabin air filter plenum. For additional information, refer to Section 412-00 .
Remove the glove compartment. For additional information, refer to Section 501-01 .
Illustration 1 of 2. Remove the components in the order indicated in the following illustration and table.
Item Part Number Description
1 14A464 Powertrain control module (PCM) electrical connectors
2 N621927 PCM retaining nuts
Illustration 2 of 2. Remove the components in the order indicated in the following illustration and table.
3 606625 PCM bracket bolts
4 031400 PCM and bracket
Removal Note
Installation Note
To install, reverse the removal procedure.
Connect the scan tool.
Select ignition control module (ICM).
Select ENTER SECURITY ACCESS. Wait 10 minutes for security access to be granted.
Select PARAMETER RESET.
Disconnect the scan tool.
Place the ignition key in the OFF position.
Place the ignition key in the RUN position.
Remove the ignition key.
Item 4: PCM and Bracket Removal Note
Remove the PCM and bracket as an assembly through the glove compartment opening.
Item 4: PCM and Bracket Installation Note
Install the PCM and bracket as an assembly through the glove compartment openin
