EGR Tube
GMAN
Spring, Texas, United States
This nut is on tight as hell. Any ideas on breaking this loose?
After all the guys say pb blaster just heat it up. I don't know how many of you guys can do exh work without torch set!! Well I live in Northeast too.
PB Blaster soak, and if that don't work, heat it first with a torch.
You might try smacking the wrench with a hammer - the shock may help start it loose (I've done it).
OK, are you saying that you need two wrenches to get the tube off? I don't want to strip anything.
When i mention heat I mean oxy/acetylene not a propane torch. If you heat red everything comes off.
