...So what are the RFI caps? First I am hearing about them.
Yes, there are a number of splices on that node. One splice splits it between the two banks, then there is a splice near each coil. Also note that it runs to two (one on each bank) RFI suppression capacitors. These are not under the coil covers. They are up at the intake manifold on each side. They ground through two of the intake manifold mounting bolts. Wire colors are Green/blue, Green/light blue, Green/yellow, Green/red, Green/black, Green/white, and Green/orange.
Also I am new to forums how do I do a quote thing?
Thanks, cap is abbreviated for capacitors. Sorry, had not gotten my coffee yet. Are the RFI's the little single gray plugs just before the COP's. I noticed they also ohm'd when I tested them. If so, I did highlight them in the diagram as well.See that "+ Quote" tag in the lower right of each post...
Joegr, I just sent you a private message. Thanks a ton for all your help.Yes, they are single conductor.
