How shitty of a job us that?
This may not be exactly in order... and I may miss something...
- disconnect battery
- remove rear half of exhaust
- remove tin underbelly heat shield pan.
- unbolt and remove rear driveshaft coupler, (color code each bolt assembly and keep in hole it came from because the coupler is a balanced assembly)
- index mark center driveshaft support and note location/direction of spacers... then unbolt center driveshaft support
- disconnect main electrical harness behind intake manifold, and relocate both halves of the harness so it doesn't get crushed when lowering transmission
- unbolt torque converter from flex plate
- disconnect o2 sensors and remove wiring from trans
- support tailshaft of transmission and unbolt rear support.
- lower transmission part way and disconnect solenoid pack harness.
- disconnect and remove vent tube on passenger side of trans, (so it doesn't get crushed)
- lower trans enough to loosen all bolts.
- you may have to loosen or remove front half of exhaust
- you will need at least one jack stand to support rear of engine
- remove all but 2 tranny bolts... leaving one on each side. Wiggle trans off dowel pins. If it wont wiggle off... you will need a propane torch to heat up the aluminum case to expand the aluminum off the dowel pins.
- put jack under trans and shim with wood to match the angle... then ratchet strap trans to jack... then remove last 2 bolts, (or use transmission jack). Ooorrr... if you and your buddy feel manly enough... you can bench press it down off the engine to the ground.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- You'll want to start with the back if the car about 18" off the ground... and the front about a foot higher... or put the vehicle on a hoist. Otherwise... the tailshaft will hit the ground before you get enough angle to pull it off the engine. Don't do this job with the rear wheels on the ground... because when you disconnect the driveshaft... you might want to change your user name to "Slim".
Reverse everything for install.
To replace the torque converter... don't stand the trans on end with all the weight on the tailshaft. Keep it flat on the ground. Support the lower part of the torque converter with your hands... lift up a little to support the weight... and pull it straight off the input shaft. You will notice the back side of the converter has a nose with slots. Those slots "key" into the pump. Also... there is a splined gear inside the torque converter... that goes on, (and turns), the input shaft of the trans. When installing the new torque converter... the trick is to catch the gear inside on the splines of the input shaft... while rotating it to key into the pump... while at the same time getting the nose past the seal without farking it up. If you did it right... the torque converter should be slightly countersunk in the case... not flush. Take note of the depth when pulling the trans... that way you have a reference when installing the new one.
Then reinstall in reverse order... making sure one bolt hole on the torque converter lines up with the flex plate, (probably best to make sure one of your bolts is at the 6 o'clock position when you start pulling the trans).
