There are some pretty crazy home made smoke machines, and you really need to be careful if your not using an inert gas to push the smoke. I have seen everything from ones that use cigars to oil lamp wicks to dry ice to produce the smoke.
I get (or got...I might have solved it) a gas smell in the cabin of the car, it usually happens when the gas level is low, but not always. I figure I need to do a smoke test to track it down. I also thought you had to somehow trigger the purge valve and/or the solenoid to test all of it.
