Another issue comes with this thing, after replacing pcm 3weeks ago, I smelled coolant burning, steam coming from coolant reservoir, and coolant leak under my drivers side. What could this be?
Ok, recap was driving, the can kicked on high, when the car was running, smelled coolant burning, turned car off, saw steam coming from coolant reservoir (degas bottle), looked down under the car, on the drivers side of the car, and coolant was leaking from drivers side, COULD this be the degas bottle? Changed coolant outlet pipe not long ago.
Did I mention that it leaks when the car is off?
At least you find a leaking part. For me, the fan kicks on randomly at full speed and dealer did the pressure test, and said AOK.
What about these dorman degas bottles, I just ordered one, are they any good?
