fastmark1993
What mods are you going to make to increase the steering angle?
I'm not to worried about the steering angle right now I think the mark has a pretty good one for how big of a car it is
my dad's 89 cougar XR7 has a center pull e brake and the XR7s were offered with a 5 speed manual as an option.
don't have any idea whether or not anything from the center console will fit though.
Wait, why would you ever need a T-56 in a drift car? Helluu? That's like putting a T-56 in a drag car.
No need for the last 2 gears.
Imo a T-5 would do just fine.
How will you improve the steering angle?
Hmm, a Mark Viii drifter in Sweden. Would be perfect because the bolt pattern is the same as on the most common Volvos!
Too bad a Marks costs way too much to turn into a drifter ...
Oh, okay then!
I thought it would only be a drifter
Wait a second.
Having 4:56 gears wont give you the best milage even if you have a 6 speed
Atleast you can be happy the gasoline is cheap in the US!
Over $8 gallon in Sweden ...
Other than the fact that a t5 wont bolt to a 4.6.
Correct.
I was only pointing out a flaw in previous posts.
 I'm keeping the sway bars a secret till the car is done. Let's just say they are thick, pink and don't mount in factory locations! Car is stiff as fock. Took the air ride out and got all t bird parts. She's low and has 0 body roll. My brother in law spent a lot of time developing these sway bars and 2 other special mounts!
 I'm keeping the sway bars a secret till the car is done. Let's just say they are thick, pink and don't mount in factory locations! Car is stiff as fock. Took the air ride out and got all t bird parts. She's low and has 0 body roll. My brother in law spent a lot of time developing these sway bars and 2 other special mounts!Where did you get a t56 for that cheap???
I have yet to be able to slide my rear end out around a corner....
t5 will bolt right up to a 4.6 if you get an early 92 block with the t5 pattern....or get an adapter made...
this should be interesting...mark viii's have too much understeer from the factory...I have yet to be able to slide my rear end out around a corner....I give you props for having the courage to do it, but a mustang would be such a better platform...the solid axle and suspension is so much better for sliding around corners...I'm not an IRS specialist, but I'm doubtful that it's going to work well with your plans
 . My 98 will kick the back end out with little effort. I had way too much fun with it when I was on worn tires.
