I hope you guys are putting a slight downward angle on these front plates. The cops that use laser are trained to sight on the front plate because when using the factory mounting method the front plate is a flat reflective surface directly facing him. A slight downward angle will cause most of the laser energy to be directed at the ground rather than back at the cop. He'll still be able to tag you because it won't be 100 percent, but his effective range will be greatly reduced. It doesn't have to be much, just 15 degrees or so, to drop his return signal enough for your laser detector to pick him up and give you time to drop a little speed before he gets his reading. The advantage will be small, but every little bit helps.
