cammerfe
Is it true that 'forscan' is a synonym for uncircumcised?
KS
KS
KS
I see in the forescan forum somebody was able to calibrate Advancetrac and make the light go out..
Not much info on how or where in the program.
anybody tried it ?
KS
^ I'm not very good at jokes but I do believe this is one!
Dear, look what I found using Forscan !!! ... I was able to adjust some settings.
Btw, I was able to do a complete brake flush by using forscan.
How so? I haven't really looked because the list of things is a little expansive and I seem to always be preoccupied with something else with the car
I was able to control the abs module and proceed with the flush. It allows me to flush the old brake fluid residing in the module itself. I'll post up a video once i return home and classes are finished.
While your at it,,,,,,,,,,,,,,.
see what you can find about calibrating Advance Trac so the light goes out ??
i would be quite interested and eternally grateful for any help in getting this light out on my dash.
i don't have a scanner capable of reading these faults. my AT light is on constantly, and of course the display says to check advancetrac. fortunately enough, it doesn't fail the state inspection. no abs, srs, or check engine lights are on. no stored codes on these. with the age of these cars; i should say the intrinsic value being what it is, i try to get by w/as economical repair as possible. that being said, the knowledge and self-satisfaction of a repair successfully completed w/o a dealer input is priceless.
It could be a calibration issue, but unless it has been worked on, it is more likely to be the steering wheel angle sensor (could also be the yaw sensor). In any event, you'd need a scan tool that could not only read the fault codes, but could also trigger the calibrate procedure. Mine can do that, but Forscan would be a lot cheaper if it could do it.
Stay tuned guys, Finals are almost done. I should be heading home on Monday. I'll be returning with answers and hopefully solutions to your questions. Heck I don't even mind playing with some controls available in Forscan for your pleasure
Any other things you guys would like to see done with the software before attempting it on your car, let me know and I'll try it first.
Any progress ??
Yep. All the videos should be up in a few days.
