SleeperMark
Ok, so as some of you know I have been battling the klunk in the front end for quite some time. It is more of a hefty knock over medium sized bumps (not a rattle). Here is what I have replaced... UCA's, LCA's, Struts (Tokico blues with red spring), inner tie rods and outer tie rods (both Motorcraft), strut rod bushings (Moog polyurethane), Wheel bearings and rotors and calipers and brake pads all Motorcraft also. The sway bar end link was done a month before I got the car, so about 40,000 miles ago. (TRW) I am at a loss here. Maybe a bad steering rack? it has NO play but at a stop in park if I shake whe wheel I can hear a quiet knocking. (even after new tie rods). The only other thing I can think of is if maybe the strut rod bushings are not completly tight. I will upload pictures in a few. Trying to get an Idea before I hear to the alignment shop today tho. Thanks
