Outkast
thats some smart shtuff right thurr.....
			I got them changed using the bolt method to press them out but nowi have abs light, brake lights on and now my advancetrac doesnt work, my trunk release doesnt work, interior lights dont come on, heater control lights do not work.Another possible approach: Mevotech makes a knuckle/ ball joint assembly for LS that costs about $90. A new wheel bearing can be installed into this knuckle easily at the workbench. Remove the old knuckle and hub and install the Mevotech assembly to the car. This at least gets your car back on the road quickly. Then at your convenience, you can do battle with old hub and knuckle at your workbench and when you feel like it. Low stress.
Do you really mean to remove the studs, or are you asking about removing the hub?Moog Bearings out again. Havent done this in a couple years. What do you use to push the wheel studs out a front end service kit? Dont remember what I did. At least they are on closeout now on rockauto..
The hubs just fell out for me (no road salt here). I do think there was a thread about using nuts on bolts to push the hub out as they were turned.
Oh man, you've got that right! Subaru hub bearings are a trip!it’s not a subaru, even the worst ones don’t take a whole lot of force to remove once you’ve got it on the press
4 months later doing it again. God Moog is awful. I was better off gambling with a 20yr old 200k mile junkyard spindle at this rate as I did with the rears. If I didnt purchase 2 Moogs on closeout last time I would be doing the same.Moog Bearings out again. Havent done this in a couple years. What do you use to push the wheel studs out a front end service kit? Dont remember what I did. At least they are on closeout now on rockauto..
If you check around... You may be able to find OEM spindles.4 months later doing it again. God Moog is awful. I was better off gambling with a 20yr old 200k mile junkyard spindle at this rate as I did with the rears. If I didnt purchase 2 Moogs on closeout last time I would be doing the same.
