Telco
Filling up at a strange gas station? Sounds like you might have picked up a tank of crap gas. It only takes one, then you have to clean the entire system. Pull the fuel filter and see what comes out. With that many miles on it assuming it's on the original fuel pump, may as well change it (NOT WITH AN AIRTEX) while you're in there.
This is also a risk at a normally good gas station when you fill your tank at the same time the gas station tanks are being filled. If there's any crap in the main tank, it's going in your tank. It takes about a half hour or so for the tank crap to settle out enough to not matter. When I see the tanker truck, I move on to the next station.
So far as the vacuum issues, the engine must be running for there to be vacuum. Just cranking over won't do it.
