Fuel Rails
Sapperfire
Waco
I would like to stick some performance fuel rails on the new motor, I'm keeping the stock injectors, anyone know of any that would be an easy bolt on for less than $200?
mine has the stock rail but has a billet adjustable fuel pressure regulator on it, you could always do something like that too just upgrade the regulator, i think you can see mine in a pic....
yeah you can see it here its annodized dark red. dont mind the red circle around the hood alarm switch we were trying to show debi where that was one night in chat. i also dont have the cobra stickers anymore i didnt put them on it!
No gain if your still using the same lb injectors. Best bet would just be a bigger fuel pump. Your motor is a stock motor. Do you have a tuner chip that is another way to achieve a better fuel/air ratio. Don't mess with the fuel rails.
Im not looking to get performance from the rails yet...going more for the look right now, then when i get more sidejobs I can do a better fuel pump, injectors and regulator will be last, that's the most expensive pieces
if you'll note...I put my budget of $200 up there
well steal one! whats wrong with the stock rail just get some 0000 steel wool and polish the hell out of it.
Drain bammage. We had this discussion a few months ago when I was putting my blower in remember? It was gonna cost me almost $400 to do an aftermarket rail.
Here is why. Any fuel rail thats not a total POS is gonna be over $100. Then its another $100 for the FPR. Then you need the fittings which will run another $80 then you need the right kind of line for the fancy fittings and thats another $50.
So unless you are uber rich like Jamie ( :p ) then its a total waste.
Oh fine, I just want my motor to look it's best...it already has an awesome paint job, just wanted to compliment it a bit more
Check with Geno he sell the fuel rails. Ya think about polishing the intake
O forgot about ya painting the intake. Did the intake tube get painted as well. Look like Sap should just open a saving account for a blower himself.
