Then why did ford WHO USED TO RECOMMEND only 5w30 in there motors, one day say HEY, lets say 5w20 from now on!!!! and all the motors that use 5w30, we will put 5w20 in them. Did they change the specs of all the old motors out there while we where sleeping to run on 5w20???
All ford did was down size the motor so it was less powerful then the more $$$$ jag.
Now did ford go through BIG $$$ on R+D on the jag motor, and make it fine to run on 5w20, or did they take the jag design, down size it, and blindly put the 5w20 oil on it like they did to all there old motors.
5w20 Will be fine, I am not saying its going to blow up your car. But Euro cars run 5w30-5w40-0w40 for a while now, they never changed to 5w20, and look how long they last.
Yes 5w20 can get you to 300-500 thousand miles easy. I am just stating jaguar has not gone to 5w20 as of yet, with there motor design. WHY is that???
No I am not a ford Engineer, and no I am not running BS. The Engines I work on cruse at about 40,000 feet.
Again, ford only used the lay out of the engine... not the exact design. Example... they took the block layout; where the coolant passages are, the way the timing chain is ran, the degrees separation in the V... things like this; the things that make two engines which are otherwise not the same fall into the same family. Everything else they designed on their own; they determined 3.9L was the ideal displacement for efficiency and power balance, they set the bore and stroke, pin height and thickness, rod length and material (oh so typical of ford... powdered metal with cracked caps), skirt length on the pistons, cylinder wall thickness and separation, bearing width, diameter and clearance... the TRUE NUMBERS of the engine, the actual specs were all controlled by Ford. There is a significant difference between using the same architecture and using the same design. The architecture of the engine is the generalized layout; the design are the specifics: dimensions, materials... things of that nature... Make no mistake... Ford Designed this engine using the AJ architecture.
There are difference between a 4.6L SOHC block (although in reality, DOHC and SOHC blocks can be interchanged) built on the Romeo line and the Windsor line. And these are two engines in the same family which are supposed to be interchangeable. The differences are night and day when you start talking about the 5.4L's vs the 4.6L's... or even the V10's (which are in the modular family). My point here is that just because an engine is in the same family and shares the same general layout... does not mean they are the same DESIGN
With that said... again, I want to make it clear... these engines are not JAGUAR engines... they are Ford engines, they simply borrowed the layout from Jag. People give our cars more credit than they deserve... they are not a Jaguar in Ford clothing... unless it just so happens that we got the retarded redheaded step child of the Jaguar family running around in Ford clothing... Anyway, joking aside.
Given that this engine is FORD's engine, they have every right to do whatever they want with the oil specs... if they want to start at straight 10 weight then through a series of changes end up at 70w85... they are free to do so and unless someone has some sort of hard data, disputing their recommendations does no good.
Did Ford make any changes to their engine that required a change in oil weights? I don't know... do you know? I doubt it. So all you're doing is guessing.
I have a 98 F-150... calls for 5w30 on the fill cap; ford put out a TSB saying 5w20 can be used. What could their motives for this be? Well, I can tell you what their motives are not... That is making an attempt to give their fleet rating a little boost. Ford doesn't gain any better ratings or any better EPA or CAFE approval by approving another oil weight for past years production vehicles. Those vehicles have already gotten their EPA ratings and that cannot be changed. So they gain nothing.
Were I to guess what happened... it would go something like this...
Ford on some of their vehicles were looking to improve emissions, mpg and general efficiency. So among various other things (changing over to coil on plug from coil packs), they tested different weight oils. Determined that 5w20 was safe to run in a number of engines... when this was figured out, they sent out a TSB to inform people that these engines have been tested for and found safe to run 5w20... oh and as an added bonus... you, the vehicle owner will get a bit better fuel mileage. IS any of this factual? Hell... I don't know. Would it be wrong if this is what happened? Nope. Does this mean engines built beyond when Ford started using 5W20 are really designed for 5W30? Nope... Does it mean they were designed for the 5W20 which they run? Nope... See where I'm going with this? We don't know any facts; we are just guessing. The end result is the same... the manufacture who warranty's these vehicles, sometimes up to 100,000 miles... advises a certain oil weight. None of us are REALLY in a position to question it.
