Gen II Front Bumper Removal
Really not. Just remember the grill comes off with the cover, and the bolts on the backside top must be removed also.
1. remove the headlights. There are 3 11mm (i think 11mm) bolts on each light. Be carefule with electrical clips... they become brittle with age.
2. While you are in the engine compartment, remove the 4 10 or 11mm nuts from the top back side of the grill.
3. Remove all the plastic screws from the botom of the bumper cover and I think there is one or two on each inner fender that needs to come out.
4. Where you took the headlights out, there are 3 push tabs... the little black plastic push-in keepers. You can try to stick a screw driver under them to pry them out or you can buy the tool to remove them. I used a screw driver, but broke the head off of 3 of them. Most car part store sell replacements in a package for about $2.00 for a package of 10.
After removing the keepers, the grill and bumper should nearly fall off.
Good luck.
Sorry for the lack of helpful information, I have not had to take my second gen bumper off yet..
Taking the first gen cover off wasn't too hard, I did that a couple of times.
