Deaconblue
I have never really liked the passive rear steering in my ’04 LS Sport. It makes highway speed lane changes too quickly/abruptly and low speed right handed turns too tightly. So when I discovered a couple months ago that after 11 years and only 39K miles that the boots on the factory rear lateral toe control links were ripped, I order a pair of DEEZA # JA-L607 fixed length replacement units.
I got around to replacing these this past rainy Sunday. The replacement job was easy, straight forward and only takes about 2 hrs. I tried to match the length of the new ones to that of the old ones by setting them side to side, using the knuckle mounting bolt through both links as a fix point and adjusting the length of the new unit to match the length old one by using a short straight edge. I did this for both sides. Don’t sweet this too much, even being this anal, I must not have gotten this perfectly correct. The car is now dog legging going straight down the street with the steering wheel off by about 30 degrees. So make sure to schedule a four wheel alignment after you replace these links.
I will reserve my final judgment on the elimination of the passive rear steering until I get the alignment done in a couple days.
