joegr
Hey 2005 LS V8
(2nd mechanic said he found these codes:
U1027 - Engine RPM - Parking Brake
U1262 - BUS - PCM Relay
Says coils look pristine and he's confident they aren't the issue. He swapped the horn relay that is rarely used with the PCM relay, which is constantly used. No limp so far. Horn still works.)
Did swapping the relays resolve the U1262 code?
U1262 SCP (J1850) Communication Bus Fault
This DTC can come from any of these:
- SCP communications network circuits open, short to ground, or short to voltage
- DLC C251
- interior AJB C283a
- interior AJB C283b
- interior AJB C283c
- interior AJB C283d
- joint connector No. 4 C223
- joint connector No. 5 C427
- in-line C315
- ABS/TC module
- PCM
- DATC module
- ACM
- FEM
- REM
- DSM
- DDM
- instrument cluster
- navigation system module
- electronic parking brake module
The fact that the U1027 came only from the parking brake, and not also from the ABS and the FEM, makes it seem less likely to be the PCM relay, but I guess time will tell.
