In 1965 I had a 327 Corvette with solid lifters rated at 365 HP. All stock from the Factory.
Yeah, but those HP numbers from that era aren't reliable, nor comparable to modern engine ratings.
That 365 HP sounds like a gross rating, not SAE (net)
I have a motor that makes close to 1.5 HP per cubic inch![]()
Fact of the matter is....the only thing the mark motor has in common with older V-8's is...
EIGHT CYLINDERS...
other than that.. two definatley different animals from every aspect of the word.
Not sure, maybe XLRV would know?
Only true way to know for sure would be to run one of those old classics on a modern chassis dyno and compare the modern numbers directly with today's stuff.
Have you tried to set up the timing chains in the DOHC with the same tools you use to put a timing chain on a push rod motor...
not too many people are good enough mechanics to "take a mod motor apart".
It's not for beginners, it's not a good project for someones first or 10th rebuild.
There are alot of places to "go wrong"... especially cam timing.
modmotors are not for budding engine builders...
I still stand by my original comment.
Of coruse if someone armed themselves with the knowledge and understanding they could successfully rebuild a mod motor.
BUT... look at the technical skill AVERAGE of the posts on this board.
DO YOU REALLY THINK these people that cant figure out a "no start issue".. or SCREW UP a fuel pump install... or cant figure out the VERY SIMPLE AIR RIDE SYSTEM are capable for rebuilding a mod motor?
Granted, you can skew this with any BULLCRAP you want.
The fact remains the same.
Take 10 users here, put them in front of a mod motor that has been taken apart and I'll show you 10 users that would have NO CLUE how to get it back together.
AGAIN.. MOD MOTORS are NOT for budding engine builders......
I couldn't imagine having to pay somebody every time I've had to troubleshoot mine and by the way I've received some great tips from this board.
