I love the paint. It looks like you could fall into it and never be found again. Very deep looking. The front looks damn good and I love the headlights, not to mention the work that went into fitting them.
The rear, I would have went with the 2011-2012 Charger lighting and wing or maybe not the wing. It looks like it would fit the contour of the lid and also go from side to side. Not sure if you have seen the Charger lit up at night from the rear but it's bad ass or to me it is. The Mark really needs that lighting across the entire rear IMO but all in all, you done some very impressive work. I like the rear 1/4 window delete but only because it's black. Not sure if it would look good in any other color. Just tossing the idea and you saying that it's not officially done, thought I'd throw the idea of the Charger lighting in there. If you haven't seen it at night, give it a look. Maybe even incorporate some LED lighting into the Lincoln emblem you already have....
Great looking custom work, tell me that grille isn't from a camaro or impala please. haha
If the trans is leaking towards the front be sure to check the fill tube for the leak as the "O" ring tends to dry out and lets trans fluid come out and it rolls down the front of the pan and trans. It is a easy fix to replace.
While you have the trans down you might want to consider installing new gears and traction lok, new fuel pump, one piece drive shaft, and replacement of any worn out rear suspension components (bushings & shocks).
one piece drive shafts are in 93 mark's only.
they come up for sale from time to time here on the lincoln sites or on ebay or junkyards.
Very very nice custom work. I looked at the picture of the interior ripped out with the miles of wiring and immediately became depressed. LOL Other than that, the car is an A-. I'm not a fan of darked out taillights so that's the only checkmark I give ya. Great job!
Thanks for the ideas. I haven't taken a close look at that but I will. It could you a little more something on the rear. I have definitely thought about the emblem lighting, just haven't come up with a good way to do it yet.
