just for $hits and giggles i was building my own IS from lexus site. they did not have those options to select the moonroof and perforated heated leather seats.
and the only option i picked was the 18 wheels. here is what i came up with as a price. but knowing me i can bring the price down!
Base MSRP* $35,440.00
• Standard Features
Available Packages
$720.00
• 18-in Alloy Wheels with Summer Tires
- 18-in Alloy Wheels with Summer Tires
Accessory Options $0.00
• Trunk mat (see dealer)
• Wheel locks (see dealer)
• Cargo net (see dealer)
• 18-in G-Spider alloy wheels (see dealer)
• All-weather floor mats (see dealer)
• Car cover (see dealer)
Delivery, Processing & Handling Fee†
$590.00
Total MSRP** $36,750.00
Here is your completed Lexus. We hope that this tool has helped you make some decisions about your new vehicle. Now that you know what your ideal Lexus will be, you can contact your local dealer to request a quote.
Lexus of Orlando
305 North Semoran Boulevard
Winter Park, FL 32792
(407) 678-2000
Map/Driving Directions
STANDARD FEATURES
Performance Features
3.5-liter V6, four cam, four valves per cylinder, with continuously Variable Valve Timing with intelligence (VVT-i) on intake and exhaust valves
306 hp [1] @ 6,400, 277 lb-ft torque [1] @ 4,800 rpm
Six-speed paddle-shift sequential automatic Electronically Controlled Transmission with intelligence (ECT-i)
Independent, double-wishbone front suspension with coil springs, gas-pressurized shock absorbers and hollow stabilizer bar
Independent, multi-link rear suspension with coil springs, inverted mono-tube gas-pressurized shock absorbers and stabilizer bar
Rear-wheel drive
Electronic vehicle-speed-sensing, progressive power-assisted rack-and-pinion steering
Four-wheel power-assisted disc brakes [2]
17-in alloy wheels with 225/45VR17 all-season tires front, 245/45VR17 all-season tires rear [3]
Estimated fuel consumption: 21/28 mpg city/highway [4]
Luxury Features
Metallic-finish interior trim
Leather-trimmed interior
Leather-trimmed steering wheel and shift knob
Steering-wheel-mounted cruise control, audio and display controls
Tilt-and-telescopic steering column
Lexus 13-speaker 194-watt [5] Premium Sound System with Automatic Sound Levelizer (ASL) and in-dash, single-feed, six-disc CD auto-changer
MP3 audio input plug
In-glass antenna with FM-diversity system
10-way driver's and front passenger's (including lumbar) power seats
Height-adjustable headrests for all seats, including rear-center
Dual-zone automatic climate control with interior air filter, smog sensor and automatic recirculation mode
Power tilt-and-slide moonroof with rotary dial adjustment, one-touch open/close and sliding sunshade
Power windows with one-touch auto open/close feature
Remote-linked window and moonroof opening
Retained accessory power for windows and moonroof
Electrochromic (auto-dimming) inside rearview mirror
Power door locks
SmartAccess with push-button start
Center console with sliding armrest, storage bin and accessory outlet
Foldable front-door storage pockets
HomeLink® universal transceiver to operate compatible garage, gate, home lighting and home security systems
Illuminated entry system
Electroluminescent instrumentation with startup sequence
Interior electronic trunk-lid and fuel-filler-door releases
Lexus Personalized Settings (LPS) [6] to personalize electronic functions
Automatic on/off projector-beam headlamps with 30-second delay
Dual chrome exhaust tips
Trunk pass-through
Carpeted floor mats
Safety and Security Features
Driver's and front passenger's advanced airbag system (SRS) with front passenger's twin-chamber airbag [7]
Front seat-mounted side airbags (SRS) [7]
Front and rear side curtain airbags (SRS) [7]
Driver's and front passenger's knee airbags (SRS) [7]
Three-point seatbelts for all seating positions, pre-tensioners with force limiters for front and outboard rear seats
Automatic Locking Retractor/Emergency Locking Retractor (ALR/ELR) seatbelts for all passenger seating positions. Emergency Locking Retractor (ELR) only for driver's seat
Height-adjustable front shoulder belt anchors
Child Restraint Seat (CRS) tether anchor brackets for rear outboard seating positions
Four-sensor, four-channel Anti-lock Braking System (ABS)
Vehicle Dynamics Integrated Management (VDIM) [8]
Traction Control (TRAC)
Brake Assist [9]
Electronic Brakeforce Distribution (EBD)
Lexus four-sensor Tire Pressure Monitor System [10]
Highly rigid body structure with front and rear crumple zones
Side-impact door beams
Reinforcements in pillars
Impact-dissipating upper interior trim
Collapsible steering column
Daytime running lights
Integrated foglamps
Water-repellent front-door glass
Variable intermittent windshield wipers with mist cycle
Rear-window defogger with auto-off timer
Power-adjustable outside mirrors with puddle lamps
Vehicle theft-deterrent and engine immobilizer system
Tool kit
First aid kit
Back to Top
Lexus tries to make sure that availability information is accurate and up-to-date. However, exact configuration details cannot be guaranteed at all times, and vehicle availability may be subject to change prior to sale.
* 2006 Manufacturer's Suggested Retail Price. Excludes taxes, title, license and optional equipment. Actual dealer price may vary.
** 2006 Manufacturer's Suggested Retail Price, including delivery, processing and handling fee. Excludes taxes, title and license. Actual dealer price may vary. Does not include accessory options installed by dealer.
† Historically, vehicle manufacturers and distributors have charged a separate fee for processing, handling and delivering vehicles to dealerships. Lexus' charge for these services is called the "delivery, processing and handling fee" and is based on the value of the processing, handling and delivery services Lexus provides, as well as Lexus' overall pricing structure. Lexus may make a profit on the delivery, processing and handling fee.
[1] Ratings achieved using the required premium unleaded gasoline with an octane rating of 91 or higher. If premium fuel is not used, performance will decrease.
[2] High-friction brakes are standard equipment for the front brakes only and require periodic inspection and measurement as outlined in the Owner's Manual Supplement. The pads and rotors are expected to experience greater wear than conventional brakes. Pad life may be less than 20,000 miles, and brake rotor life may less than 50,000 miles, depending on driving conditions.
[3] Tires fitted with 17- or 18-in wheels are expected to experience greater tire wear than conventional tires. Tire life may be substantially less than 20,000 miles (17-in) or 15,000 miles (18-in), depending on driving conditions.
[4] EPA-estimated ratings: 21 city/28 highway mpg. Actual mileage may vary.
[5] 194 watts at 0.1% THD.
[6] The Lexus Personalized Settings (LPS) program is a one-time, complimentary offer for new 2005 model year vehicles and newer purchased or leased from 10/1/04 and beyond, as well as 2006 model year vehicles, up to 12 months from the date the vehicle is sold to the first retail purchaser or the date it is first used as a demonstrator, lease or company car, whichever occurs first. Please see your Lexus dealer for more information.
[7] The Lexus driver's and front passenger's airbags, front seat-mounted side airbags, driver's and front passenger's knee airbags and side curtain airbags are Supplemental Restraint Systems (SRS). The driver's and front passenger's airbags and driver's and front passenger's knee airbags are designed to deploy in severe (usually frontal) collisions where the magnitude and duration of the forward deceleration of the vehicle exceed the design threshold level. The side airbags and side curtain airbags are designed to deploy in certain types of severe side-impact collisions. In all other accidents, the airbags will not deploy. To decrease the risk of injury from a deploying airbag, always wear your seatbelt, sit upright in the middle of the seat, and do not lean against the door. Do not put objects in front of an airbag or around the seatback. Do not use a rearward-facing child seat in any front passenger seat. The force of a deploying airbag SRS may cause serious injury or death. Please see your Owner's Manual for further instructions. Vehicle complies with "advanced airbag" requirements of FMVSS 208.
[8] Vehicle Dynamics Integrated Management (VDIM) is an electronic system designed to help the driver maintain vehicle control under adverse conditions. VDIM is not a substitute for safe driving practices. Factors including speed, road conditions and driver steering input can all affect whether VDIM will be effective in preventing a loss of control. Please see your Owner's Manual for further details.
[9] Brake Assist is designed to help the driver take full advantage of the benefits of ABS. It is not a substitute for safe driving practices. Braking effectiveness also depends on proper brake-system maintenance and tire and road conditions.
[10] The Lexus Tire Pressure Monitor System alerts the driver when tire pressure is critically low. For optimal tire wear and performance, tire pressure should be checked regularly with a gauge; do not rely solely on the monitor system. Please see your Owner's Manual for details.
Specifications, features, equipment, technical data, performance figures, options, and color and trim are based upon information available at time of posting, are subject to change without notice, are for mainland U.S.A. vehicles and may differ in the state of Hawaii, Puerto Rico, the U.S. Virgin Islands and in other regions.
