After all the talk in here about the JMod, I decided to have it done, well after spending $116.00 on the parts and another $150.00 to have it done, its not worth it, to be honest, I haven't noticed much of a difference. Geno you were right !!!!
Cubster said:After all the talk in here about the JMod, I decided to have it done, well after spending $116.00 on the parts and another $150.00 to have it done, its not worth it, to be honest, I haven't noticed much of a difference. Geno you were right !!!!
ONEBADMK8 said:Told ya'
seanklsc said:I have to disagree. Since day one when I bought my car I knew I had to do something about the laggy tranny I had. I was a member of Lincoln forums for a while so I knew all about the problems our trannies have, so it didn't bother me much. One day I had the 1-2/2-3 accums serviced, Mercon V, and Jmod to 300hp spec and it was a world of difference. The tranny shifts smoother and faster and its much more enjoyable than before. I'm not able to chirp gears but I wasn't able to before either. It bangs right into gear with no lag at all. I haven't tracked tested it but I did put a few hundred miles on it and I would recommend this free mod to anyone, especially since they should service the accumulators anyway.
I agree with sean 100%! The j-mod is by fat the most noteable mod I have ever done on any car. My car went from a sloppy, slippy tranny, to a fast, hard shifting power tranny by doing that mod. Did you do the entire mod or just part of it? Did you drill the holes in the plates and everything? If not, that's why u can't tell a difference. The j-mod includes all of that stuff.seanklsc said:I have to disagree. Since day one when I bought my car I knew I had to do something about the laggy tranny I had. I was a member of Lincoln forums for a while so I knew all about the problems our trannies have, so it didn't bother me much. One day I had the 1-2/2-3 accums serviced, Mercon V, and Jmod to 300hp spec and it was a world of difference. The tranny shifts smoother and faster and its much more enjoyable than before. I'm not able to chirp gears but I wasn't able to before either. It bangs right into gear with no lag at all. I haven't tracked tested it but I did put a few hundred miles on it and I would recommend this free mod to anyone, especially since they should service the accumulators anyway.
MonsterMark said:What parts did you buy? The JMOD consists of drilling out a couple holes to a larger diameter, thus allowing the transfer of more fluid, which equals faster reaction. Maybe they got you for the special size drill bites.![]()
Post up the invoice and we'll tell you if you got hosed.
Cubster said:Bryan, I called Max, I told him I was doing the JMod, I asked him to send me the parts I needed, they (the parts) came to 116, there wasn't any drill bits included, much to my dismay.
BlackIceLSC said:no one will win this arguement. It is all a matter of opinion. However, keep in mind one CRUCIAL element. The JMOD is NOT a shift kit. The JMOD is a modification(MOD) to the separator plate. That is ALL. Basically, the holes that are in the separator plate have been RESTRICTED to soften the shift. The transmission was built to shift quicker than it does. The JMOD is simply opening up the holes to allow the 4R70W to shift the way it was intended. That is ALL.
The only "cost" is two separator plate gasgets. If you also replace your shift accumulators, that is NEEDED anyway, so it isnt considered part of the JMOD expense.
I fear baumann kits based on the damage I have seen them do.
I stand behind Jerry's Mod 110%, and have performed 5 of them to date, all with perfect results, and happy owners. if the JMOD didnt improve the speed of your shift, or the firmness, then something is wrong. Either that, or your tranny had accumulator problems prior.
There...to each his own. But if you saw the scraps that came out of a 80k mile tranny that had a baumann kit installed, and failed...you would fear them.
True, but Jerry, the guy that helped develop the 4R70W has said in his thesis over on TCCOA not to ever touch the EPC. He never really gets into why. Kind of telling a kid not to put a paper clip in a light socket, but not the reason why.l-m tech said:if you want a little firmer shifts with out drilling the seperator plate or having to buy a shift kit,try removing the epc solinoid while you are replacing the 1-2 and 2-3 accum. on the side there is a t-15 torques screw that you can turn 1/8 to 1/4 of a turn clockwise,dont go counterclockwise or past 1/4 turn.this will bring line p[ress. up causing firmer shifts,the only thing you will notice is harsher rev/forw. engagements.this is the alternative i use instead of buying a shift kit.
