Well that may just be what I do then. Do you think it could make it until mid march?
That depends on your driving habits. My original solenoid pack started giving me major symptoms at around 110k miles. Tne symptom was a hard "bang" downshift to first gear when coming to a stop, (after driving 65 miles on the highway).
I finally got to the solenoid pack change... at around 135K miles... and all was good until a very hot summer a year or so later. I noticed that when leaving a certain gas station, (with a major slope), that the trans was slipping.
I'd shut the LS off and wait 30 seconds... and all was fine. I determined the fluid was low... and solenoid pack was getting hot, (due to lack of fluid cooling).
So I added roughly a quart or more... (putting me close to 10+ quarts on a tranny fluid change on the LS. Then again... since most LS torque converters aren't drainable... I'd start the engine and let the tranny fluid spray out the bottom for a few seconds.
Done this for years, (i'm sure Joe's hair is standing on end at this point)... but the idea was to get all old fluid out without burning up the pump or torque converter. It worked for decades,,, when we had a dipstick. Usually good for an extra quart or 2.
Worst case scenario... if you overfill the 5r55s tranny on the LS,,, fluid expansion will cause the fluid to flow through the "breather tube" on the passenger side of the tranny,,, making an appearant leak on the passenger side of the trans... or causing the overflow of excess tranny fluid to dump into the bellhousing area.
