joegr
Well, your three best guesses on the shifting would be the solenoid assembly, the valve body, and the PCM.
If they actually disassembled the valve body when the transmission was open, then you can eliminate that one. On the other hand, there's really no way to be sure on the solenoid assembly just by looking at it or even doing electrical tests.
The PCM can be ruled in or out with some simple tests. They need to measure the solenoid drive current and verify that it matches the current level that it was commanded to be during the testing. If they don't understand that or want to do that, then you can remove the PCM and ship it to SIA for testing/repair. (If you get it tested locally and it fails, you'll still have to ship it to SIA for repair.)
Lincoln LS ECM / ECU Repair & Return - SIA Electronics
This has worked out for several on here.
For the door lock, is it just the driver's door? - If so, then it's the DDM (Driver's door module) or more likely the door latch assembly.
If it's all doors, then probably the DDM.
If it's the three passenger doors only, then the DDM, the CAN wiring, or the REM, probably.
