RigsLS
- Joined
- Mar 10, 2012
- Messages
- 7,756
- Reaction score
- 532
The RFI that joe speaks of, coming from a bad coil, if it's #4 on a V8, so close to the PCM, is known to throw a misleading false bad Throttle Body and Position sensor code. It'd go into failsafe mode eventually and exhibit all sorts of rough running and banging transmission symptoms. Ask me how I know. Replaced all eight coils and plugs and problem gone.
That's not to suggest this is what your problem is, just merely an agreement with Joe that bad failing marginal coils will/can irritate the nearby PCM. Not to mention ruin a perfect good set of expensive Catalytic Converters.
