2002_lincolnLS
Custom User Title
how many gallons did that take?
$200-$300 is quite cheap for materials compared to real paint...
while you may not need quite as many gallons for the job, there is usually quite a lot more materials needed. sealer/primer, color coat, then clear coat. then there is the sanding, and the sanding, then the polishing... real paint is quite a bit more time and work.
also Dip also lays much easier than standard auto paint, All imperfections show ten time worse.
Dipping a car definitely has its upsides and you would be hard pressed to a value that good.
