RigsLS
- Joined
- Mar 10, 2012
- Messages
- 7,756
- Reaction score
- 532
I did add a little coolant to this tank...
Get it out ASAP, try to save the pump, you haven't had it in long enough,
you just added more work for yourself, you MUST get it all out, refresh it with fresh ATF, turn on A/C and get that pump running and redo it several time until it's cleared up and looks like fresh ATF fluid. It will begin to bubble up with air and look like pink foam, many have made this mistake and had to either get a new pump or retro fit to the electrical fan conversion.
Flush, Flush and then Flush some more .... you might actually be better off now and pull the bottom line and drain all of it from there.
If the car has ran since you added coolant to it, you'll have to run the A/C and redo many of times. you want clean fresh ATF in there.
Be sure no one ever goes near it again and don't let any oil place changers mess with it from now of on. Lesson learned!
