After cleaning the MAF last night I was still having subtle idle issues but the car didn't die. I decided to remove the tune and things seem to be better, I did have the idle rpms set higher with the tune when I had the HO aftermarket alternator on to compensate for the lack of output at lower idle rpms.
I'm not sure if that did it but it most definitely seemed to help. Also, I unplugged the MAF and the car stumbled briefly before leveling out and idled fine, when I plugged it back in the car died - is this a sign of a defective MAF?
Would be convenient if that was the issue with idling and possible cause of my lean conditions.
And thanks for the responses so far.
