jcjaguares666
Can Anyone Tell Me How To Pull Out Or Take Apart The Hydraulic Radiator Fan???
That's a good amount of work but I found these instructions for when I pulled mine out:
1. Disconnect the throttle position (TP) sensor and the idle air control (IAC) valve electrical connectors.
1. Remove the bracket.
1. Remove the bolts.
2. Remove the bracket.
3. Disconnect the high pressure cooling fan bracket and line.
4. Using the appropriate special tool, install a new O-ring on the power steering pressure hose fitting.
5. Separate the return hose from the fan shroud and position aside.
6. Remove the two bolts and position the fan shroud assembly.
7. Disconnect the return hose from the cooling fan and shroud and remove the cooling fan and shroud assembly.
8. Remove the A/C condenser. For additional information, refer to Section 412-03 .
9. Disconnect the lower radiator hose.
10. Remove the two bolts and position the multi-cooler assembly aside.
11. Remove the bolts and the condenser support brackets.
12. Remove the radiator.
