Yeah, I probably replaced the wrong ones (although they needed replaced anyway, as the bushings on the far side were real soft). So, it's possible that the bushings on the other side of the strut might be bad? (I assume you are referring to the ones where the strut attaches to the LCA, right?)
For the side that goes through the frame, try that PC Blaster stuff for a couple of days. That and my trusty pipe wrench broke the nuts loose with a minimum of fuss. I'll check the other bushings.
