Riles
Welp, I'm here again with the next problem of the week. I feel bad that I never have anything to contribute to this website, since every week the problem I'm encountering is something I've never dealt with before.
Anyway, on to this week's problem....
My transmission is making noises and shifting strangely. Here are the symptoms:
1. "Whirring" noise whenever the engine is running
-This noise is concurrent with engine rpms, not vehicle speed
2. Car can stay in gear just fine for a few minutes after letting it sit for at least 10 minutes, then it starts to slip out of any gear that it is in and the engine can spin without affecting speed
3. Car takes a long time to switch between drive and reverse, then back into drive (this could take up to 30 seconds now)
4. Selectshift keeps me going on the highway (4th gear seems to slip less than 5th), but when starting from a stop, I can't shift out of second. I can put it back back into D5 to let it shift itself, then I can go back to using selectshift
5. 3rd and 5th gear seem to be the worst, although occaisionally 2nd gear sucks too
I can't decide on whether this is a solenoid pack issue or if the actual transmission is slipping. Problems 3-5 (from above) lead me to believe it is solenoids, but problem 1 and problem 2 scare me into thinking it needs a rebuild.
I've only had the car for about 20k, so I have no idea if or when the transmission was serviced.
EDIT: I forgot to mention that this has been going on for 2 days, but the check transmission light just came on today, although it went off after I restarted the car. Can I scan that with a normal OBD scanner?
