JayBay
I'm trying to help out a buddy with a 2002 STS and a limited budget.  He recently had a tune-up done by a non-Cadillac mechanic.  Just to clarify, this is a certified mechanic, just not a Cadillac mechanic.  He did plugs, fuel filter, and  tranny service.  The hope was that all this would clear up a rough idle and cause an increase in fuel economy on a 100k caddy.  After tracking down a vacuum leak in addition to all the work, the rough idle went away and the fuel economy went up.  However, the check engine light has reared it's head again,  and the mechanic said the code indicates catalytic converter failure.  The car seems to run great - but it won't pass emissions inspection with the check engine light on.
So - assuming this code is correct and the car does need a catalytic converter, we began research on replacing it--only to find out Cadillac sells it as a unit with much exhaust pipe on either side to the tune of $1000 for the part alone. Finding this unacceptable, we checked some other resources. When entering year, make and model, most online parts stores kick back a "universal" catalytic converter. This brings me to three questions;
1. Will the universal catalytic converter work? (Understanding the old one would have to be cut out and the new one welded in).
2. Is it possible that the code is erroneous, and possibly caused by the lean conditions that existed prior to tune up?
3. I've read a few references on this board to on board diagnostics. Can somebody post a reference link where I can learn more about this?
Thanks!
Thanks!
