try this
1. Enter the factory keyless entry code.
2. press 1/2 button
3. press one button on each of the transmitters.each time the trans. is programmed successfully, the car will lock and unlock.if they don't your trans. was not programmed.
If you mess up your previous trans. will not work either.
Behind the glove box there is a plug on the left hand side. You short the system. You hear the locks cycle then push the lock button on the transmitter. Cycle it twice to get the second transmitter.
I do not know if it is like this on all the other year Continental's, but the 1988-1994 glove box is one of the easiest to get out, just push two tabs in.
