Help with seat belts
Black03 said:
yeah, you have to do the 9x thing, then dont you do it once more for a confirmation or something? Been a couple weeks since I did mine.
correct and you have to do the same for the passanger seat since there is a weight sensor in the seat.....man this car is amazing
yes 2002 is 3x parking lights 3x yada yada, 2003 is 9x's. they are different. The online manual said have the e-brake pulled, i didn't try it w/o it pulled so i don't know for sure.
Once you start your car, just press on the seatbelt unlock button and it will refrain from reminding you from then on.
I got this off a previous post and copied and seved it to my email so I cant remember who wrote it originally
Seat Belt Deactivation/activation Programming Procedure.
BeltMinder feature One time disable
Any time the safety belt is buckled and then unbuckled during an
ignition ON cycle, BeltMinder will be disabled for that ignition cycle only.
Deactivating/activating the BeltMinder feature
Read steps 1 - 9 thoroughly before proceeding with the
The BeltMinder feature can be deactivated/activated by performing the
following procedure:
Before following the procedure, make sure that:
² The parking brake is set.
² The gearshift is in P (Park) (automatic transmission) or the neutral
position (manual transmission).
² The ignition switch is in the OFF position.
² All vehicle doors are closed.
² The driver's safety belt is unbuckled.
² The parklamps are in OFF position.
To reduce the risk of injury, do not deactivate/activate the Belt
Minder feature while driving the vehicle.
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT
START THE ENGINE.)
2. Wait until the safety belt warning light turns off. (Approximately 1-2
minutes.)
² Steps 3-5 must be completed within 60 seconds or the procedure will
have to be repeated.
3. Buckle then unbuckle the safety belt three times, ending with the
safety belt unbuckled. This can be done before or during BeltMinder
warning activation.
4. Turn on the parklamps, turn off the parklamps.
5. Buckle then unbuckle the safety belt three times, ending with the
² After step 5 the safety belt warning light will be turned on for three
seconds.
6. Within seven seconds of the safety belt warning light turning off,
buckle then unbuckle the safety belt.
² This will disable BeltMinder if it is currently enabled, or enable
BeltMinder if it is currently disabled.
7. Confirmation of disabling BeltMinder is provided by the safety belt
warning light flashing four times per second for three seconds.
8. Confirmation of enabling BeltMinder is provided by:
² The safety belt warning light flashing four times per second for three
seconds.
² Followed by three seconds with the safety belt warning light off.
² Once again, the safety belt warning light will flash four times per
9. After receiving confirmation, the deactivation/activation procedure is
complete.
