Help ?
what can get it out
If it just keeps spinning then no REAL threads are there. Take some electrical tape and stick/lay some inside your plug socket so its tight on a test plug. Push hard on plug and then loosen as you pull up. You will need to time cert that hole.
not working it there anything you can think of that small that can fit that i can pull it out with
If its loose enough to spinn easily
A fresh spark plug socket (nice tight rubber inside) should pull it out as you loosen it.
I got it out so the car have new valve cover gasket new plugs and coils and it still missing and now it won't move in drive I'm done with the car how can a transmission go from siting for a couple months I guess I'll take the lose and wait for the 15 stang
