high speed vibration
some have had success replacing hubs... others with road force balancing.
Have someone drive a "chase" car and take a look at that wheel (look at all of them, if it's not that one) while you are getting the vibration. Maybe seeing the movement of the wheel will give some clues about what is going on.
I'll inspect the rotors and inquire about the road force machine. How do I decide if the hubs are bad?
When my hub went bad it made a noticeable noise. However, some have reported no noise. Check the wheel for "play"
Thanks all. The new bolts and nuts came in and I got those on. I also had the tires rotated and balanced by a shop with a force machine. The final result is the wife is happy and the car rides smooth as butter again.:cool:
