Jus found out my compressor went and the dealer is charging me 1300 for the job...yea ok lol I got the compressor and I'm doin it myself...I do most of my mechanic work but being I never did a compressor I need some help...
if they are going to do all of the stuff that is required to keep the contamination from the failed compressor from killing the new compressor.
just let the gas out, and remove it, install a new one, then goto a shop and tell them you want to vacuum/charge your system, youll only pay maybe 300 total, worse comes to worse, when they go to vacuum the system, they may say you need to replace an additional part of the system to assure it wont fail,
if there where small shavings of metal from the compressor that got into the rest of the system, it will just destroy the new compressor, costing him more money than just having the shop do it the first time (price of compressor he has, then price of new compressor to replace the newly ruined compressor and the labor to do the job)
i agree, but for the quick cheap fix, most of the reason the compressor fails is the clutch/pulley part, if you catch it early, the internals shouldnt be ruined yet
cars have had low pressure switches in the A/C system for a long time. so the compressor will not kick on if the charge is low. im new to the LS but this is something all cars have. you defiantly want to flush out the lines and change the orifice tube. the orifice tube is just a filter. get a cheap flush kit like this http://www.jcwhitney.com/flush/p2002878.jcwx?filterid=c2283j1 its as easy as blowing up a pool floaty. replace all the o rings and you will be good to go. its really not hard to do.
can you drink it alsoits all 134a now and it can just be released into the air.
A common compressor failure mode for the LS is for the compressor to leak from the lower part of the seal where the two halves of the compressor go together. When this happens, the compressor oil leaks out before the R-134a does. Therefore it is far from unheard of for the compressor to come apart before enough R-134a has escaped to cause the low pressure cutoff to activate.
OK still learning, but if i did have an orifice tube it would act like a filter. it even looks like a filter. but it doesn't.The LS does not have an orifice tube. It has a thermal expansion valve. Also, orifice tubes are not filters. They are a fixed restriction (an expansion valve is a variable restriction) that separates the high pressure liquid from the low pressure gas.
pleas explain. again my little mind cant understand how flushing the A/C system would hurt the new compressor. or why it would mater what type of compressor it is as its not even in the picture when the flush is performed.Lastly, note that the AC compressor on the LS is a variable displacement type. Have fun using that easy flush kit. It'll only cost you the new compressor.
its best when mixed with vodka. its kinda like red bullcan you drink it also
Took my 02 LS to the shop today to check the A/C. It usually blows hot if the outside temp is > 90. Or it works when it wants to very frustrating. The mechanic said the compressor was shot and it would cost $1300 to repair (as stated in the initial post of this thread).
Recently my car has been overheating (after researching on LVC this could be a result of the compressor as well??) and I was wondering if the thermostat needs to be replaced too. If I replaced the thermostat could this correct the issue w/ the AC? Or is this problem all about the compressor? Can anyone confirm???
and the overheating - if it's fan related - could be a cause of your AC issue since the fan is needed.
The compressor is tough to get off the car - there are two blind bolts that are at the top of the compressor - one behind the coolant manifold on the compressor - it took all my extensions, u-joints, and some swearing to get them.
Is your AC clutch coming on at all? if the clutch is engaging, but not spinning the compressor - you may just have a worn clutch (which was my issue) and you can replace that yourself.
If the clutch is not coming on, and the fuses are ok, then maybe it's a low pressure issue - which you can test by shorting across the presure switch - it the clutch engages then you know it's low pressure.
