How dose Advanctrac work?
Silver02Sport
Coral Springs
Dose anyone know how Advanctrac works is it gryoscopic or what I know it uses the ABS but how dose it know your going out of control and what do is take to trigger it so far the only thing I have been able to do to test it is doughnuts.
From LLSOC/FLM
The AdvanceTrac system is an interactive yaw control
system that improves the stability of the vehicle in
extreme driving situations. It does this by comparing
the driver’s intent with the reality of the driving
experience. AdvanceTrac assists the driver in critical
situations when oversteer or understeer may send the
vehicle out of control.
AdvanceTrac enhances the traction and maneuverability
of the vehicle by managing the outputs of the
following systems:
• Anti-lock Braking System (ABS)
• All-Speed Traction Control
• Yaw control stability system
The primary sensors used by AdvanceTrac are:
• Yaw rate sensor
• Lateral accelerometer
• Steering sensor
• Wheel speed sensors
• Master cylinder pressure sensors
AdvanceTrac constantly monitors vehicle motion
relative to the driver’s intended course. The driver’s
intended course is determined from steering angle
and vehicle speed. The motion of the vehicle is
inferred from a yaw rate sensor, lateral accelerometer
and wheel speed sensors.When there is a
discrepancy between the driver’s inputs and the
vehicle motion, AdvanceTrac changes the tractive
force at the individual tires to help control the vehicle.
In this way, the driver will have better control when
braking, accelerating and cornering during extreme
driving conditions. This means if LS drivers take a
turn too fast or maneuver quickly around an object in
the road, they will have the reassurance of highperformance
technology assisting in the control of
the vehicle.
Hope that helps...
And it flat out works. Saved my kids life one day when he hit the first rain storm in several weeks. There was a ton of oil on the road that floated to the top of the rain. He barely made a wiggle to get off the interstate off ramp and the car went sideways. He knew he was in deep doo doo. He said the next thing he knew the brakes started doing something, he could hear noises, and the car went perfectly straight. This is a GREAT system.
punctuation is your friend. :slam
Bacurus said:
At least there is one period in that make believe sentence.
Didnt your mama teach you anything?
If you have nothing nice to say, dont say anything at all! argue2
You know the funny thing is if you look at any of my other posts I try my best to make sure my grammar is perfect, I was just in a rush when I posted this one. Though as far as I can tell I am just missing one period and a couple of commas it could have been much worse.
Punctuation
Yo! Shizzle, my nizzle. Why you be trippin' like that? One must contemplate the meaning of punctuation. However, on a board like this it does not matter. Please teach proper gramatical skills elswhere! See Ya, New Guy :N
A joke is your friend. See Ya , newer guy!! :waving:
