htrdlincoln98 hows life out on the eastern shore I lived in Pocomoke for a few years and spent allot of time in Salisbury.
As for my 60ft times, there terrible not much better then stock, I have to dig out the last slips but I believe my 12.98 run was at a 1.92 60ft time. My wife ran the car first and pulled a 13.1 and I was pissed so I ran it, The wife is a little more conservative then I am launching. My 12.98 run was the last run because I took out the converter, I blew the tires off past a 100ft then again into second zero traction, but pass the traps at close to 118 car comes on like a bat out of hell. If I could get traction I probably would be close to a flat 12.
Remember I have put a lot into the engine and trans,
Cobra crank, H beam rods, KB pistons 11.3 to 1 comp., port and polish, Isky proto type split pattern grind cams, modified split runner cobra intake with 1/4 inch hat spacer, 1" throttle body spacer, under drive pulley's, Steeda timing adjuster. The chambers are mirror polished and CC'ed, the IMRC's and throttle body have been modified cut back and polished along with the 90MM MAS, cut back j gaped plugs indexed 90 deg fired by MSD coils, 16deg base timing 32 total, matched flowed EV6 injectors, and about 10 hours on the phone with Sniper to get a working tune.........
Baumann 3500 stall and stage 4 kit, 3:73 gears and loc.
I need to keep it totally street able it the wife's daily driver she drops off and picks the kids up from school in it.
She wants the fastest car she can get and still drive it every day, she really wants flat 12's high 11's:shifty: so now i am looking into power adders again and I am really a NA type guy
