DLF
ok i will check pin 3 right now
You might not get a full 12 volts, the output is modulated (that's the purpose of the FPDM), so you may see as little as 6 volts output from the FPDM.
pin 3 shows no power either, and i double checked #10 still nothing, so i guess next question is how much do you think that FPDM will cost me?
well dang i need to get a different tester then, all i have is the tester light that you clip to ground and poke through the wire insulation, but i guess those testers don't even work unless it is a full 12 volt current?
you wouldn't happen to know a link to that focus fuel pump?
i will pick up the right tester ASAP, would you mind if i hit you up and if you have the free time maybe helping me like you are doing tonight?
on the fuel pump, to buy one.
Just a question if the crank sensor is not working wont that keep the fpdm from having the 12v to the pump?
I ask cause a crank sensor is much more common problem.
My 97 ate the FPDM, you could tell by the outside, it was cooked.
Same thing new pump, no fuel at the rail.
I thought I read somewhere other FPDM's will work, they just have a different mount.
no i don't have a code reader, i just go to auto zone and have them plug it in there, and i haven't got the multimeter, i've been busy, but i will try to remember to get one tomorrow
