I want some HID's
Newbie question here. How do I know if I have HID's or not? I am pretty sure I do but want confirmation. Is it as easy as pulling out the light and comparing the bulbs? Thanks in advance for the help.
n8
n8
You can tell by looking at the unit after removing the cover that goes across the top under the hood. The HIDs have a "Danger High Voltage "warning sticker. You can also tell two other ways. 1. Watch as the low beams come on in a darkened garage. If they flicker and then go bright white, they are HIDs. 2. You can turn on the High & low beams and if the low beams are obviously whiter than the high beams, you probably have HID low beams. I say probably, because if the bulbs have been switched to Hoen's then number 2 will not apply.
I live in NJ and i've never heard about anyone getting their headlights stolen but i'm know camden and willingboro are COMPLETELY different from around here.
If i didn't have the black sealant i would definitely be looking to put HIDs in but until i find a new pair i'm stuck with just changing the bulbs
